Freightliner FL80
Marty in Mi.
05-29-2005 06:08:33
Bought one last week.Has 5.9 Cummins in it.Makes very little power under 1900 rpm.Has 24 ft.aluminum box on it,plus a small stand-up sleeper.Planning on using it for a tractor hauler once I get a hydralic ramp built for the back.Is there anything I can do to the pump(without pulling it off) to make it have a little more grunt under 1900 rpm?With the Fuller 6 speed,every time I shift up a gear,I am under the rpm range where it makes any power.Any thoughts or suggestions?Thanks in advance. Marty
massey85
05-31-2005 06:21:03
 Re: Freightliner FL80 in reply to Marty in Mi., 05-29-2005 06:08:33
dave mitchell at enterprise engine in ohio can
make the 5.9 out work the 8.3. best in the business, check him out and you will agree.
R.D.F.
05-30-2005 14:43:57
1st of all you bought the wrong combo. That 5.9 doesn"t have enough poop to power a pickup much less a real truck. We"ve got 2 FL 70"s with 8.3"s, one, pre-computer, installed a TST torque plate, boosted the torque 50%, now that works with about 1000# of torque. The other is a 24 valve computer pump and it"s pretty good. Look up www.TSTPRODUCTS.com, it works and is easy to install and cheap too, it will make a world of difference in your 5.9 too, Dale
Bryce
06-01-2005 18:04:02
 Re: Freightliner FL80 in reply to R.D.F., 05-30-2005 14:43:57
I have a 99 cummins that (won't pull poop) runs darn good , with a chip & bigger injectors.It won't pull the world at 80 mph that everyonelse has but I'll take 13.5 @ 65 with 15000 behind it anyday!!!
champspa
05-29-2005 06:54:41
go to www.turbodieselregister.com and search the site . if its a p7100 pump it's easy a v44 pump even easier.
