MAX BORE
WONDRING
05-28-2005 09:27:18
WHATS THE MAX BORE YOU CAN GO ON A JD 60 BLOCK???
JDGnut
05-29-2005 14:33:18
 Re: MAX BORE in reply to WONDRING , 05-28-2005 09:27:18
Some have used 70 gas pistons and gotten away with it.. and I have seen them break the cylinder walls with 70 pistons.. All depends on the casting.. and how pitted the water jacket is..
JDGnut
buickanddeere
05-29-2005 09:13:22
On a stock block, the displacement and HP changes little boring 45,90,125 or 250. The TSC power blocks/pistons are big deal because of being 1/2" over and more compression.
Lwd
05-29-2005 01:29:02
I have a 60 power block that is 6 1/8, have heard of one that was 6 3/8, I used 720 dis. pistons
730-LP
05-29-2005 18:09:42
 Re: MAX BORE in reply to Lwd, 05-29-2005 01:29:02
I have an A with a power block 6.125 with G m&w style alum pistons in it as for the standard 60 block I would think that .250 would be about the limit. unless the block needs boring to true it up money would be better spent on cam,head work or pistons with the wrist pins lowered to push the pistons closer to the top.
LWD
05-31-2005 00:05:34
 Re: MAX BORE in reply to 730-LP, 05-29-2005 18:09:42
I have 8 3/4 stroke, 4020 rods, so no problem getting closer to the top.
