who to get to grind a crank
crank?
05-27-2005 11:30:29
looking for someone to stroke a crank. positive and negative feedback of past experiences with different grinders appreciated. thanks
crank help
05-28-2005 22:12:26
 Re: who to get to grind a crank in reply to crank?, 05-27-2005 11:30:29
Try Crank Machine Service in New Baden Ill. He welds up and can stroke to 10". Ask for Dan 618/401/2386
Brutus
05-28-2005 05:13:54
I have also seen some of Merfelds work, on the scrap heap! When he builds big cranks for Deeres he lays plate on the journal so he doesn't have to weld so much. Any idiot would know that won't work and doesn't for long. I think his dad Bill did better work.
jd b puller
05-30-2005 21:28:24
 Re: who to get to grind a crank in reply to Brutus, 05-28-2005 05:13:54
Before you go bashing people, you might want to look into that a little. If I remember correctly, he tried that (welding a plate in there) a few times, mainly becuase people were trying to get the job done quicker and cheaper. I haven"t heard of that for quite a while.
Brutus is right
05-28-2005 20:09:25
I know exactly what you mean!! I have seen 3/4 of a Deere crank he did.....and where it broke you could look in the journal and see the plate he welded in there. It is like a huge crack in there to begin with because you can't weld under the plate and there is no fusion of the plate to the journal.
42Farmall
05-27-2005 16:51:38
Keith Merfeld ground the one in my H. I've been pleased with it. Ship it to him and he will ship it back.
Earl-IL
05-27-2005 15:33:35
Where do you live??? The crankgrinder always gets the blame when a engine fails. If you have a crank redone and you install it and don't find a problem at that time more than likely the grind job was ok.Check your bearing clearance and check the finish thats the best time to correct a problem.Let us know someone can help you.What brand is the tractor?? Earl In Illinois
crank?
05-27-2005 15:56:57
 Re: who to get to grind a crank in reply to Earl-IL, 05-27-2005 15:33:35
I would like to find a grinder in the MD, WV or PA area so I dont have to ship, however, will consider others. Tractor is a Farmall M. Have spoke to a few grinders around the Baltimore area and no one does anythign more than offset grinding the existing journal. I am looking to have the journal welded and ground to stock size, so I can use stock rods.
Trkr
05-28-2005 18:45:37
 Re: who to get to grind a crank in reply to crank?, 05-27-2005 15:56:57
Had a guy stroke a M crank for me,wasnt cheap,kind of arrogant,downtown Baltimore but it was a good job, has stayed together for years.Cant think of his name (crs)it was off 25th st on a side st down near Loch Raven Blvd.Would know the name if I heard it again.
Earl-IL
05-27-2005 20:58:35
Try Moreland Crankshaft in Easton, Maryland 1-800-947-0061 or 410-822-2500 I know they do some beautiful work on the splines on Deere cranks They can weld. Earl
Bryce
05-27-2005 19:55:38
I too have used Kieth,going on 6 years on the same crank no trouble.However he is in Dubuque,Iowa and as I see you are from the east but I will tell you this ,he will get the next one I do.Hope this helps.
peterbilt007
05-29-2005 12:41:20
 Re: who to get to grind a crank in reply to Bryce, 05-27-2005 19:55:38
If Iwas going to have anyone do a crank of any brand it would be Jim Benjamin from Webbervile MI. You will not get better job anywere. He does all cranks for Gary Baker. Both of them stand behind their work.
