M Vs Super M Motor
Mperfection
05-26-2005 18:19:32
I found a super M short block and was wondering if there was a difference in stroke from a regular M. I know the bore is bigger but the cranks each have different numbers. I will buy it regardless so i can slowly build up a second motor. Thanks for any help.
ChadS
05-27-2005 06:42:02
 Re: M Vs Super M Motor in reply to Mperfection, 05-26-2005 18:19:32
If it has the cam in the block too, thats good!!! its a better cam than the old M's had. find a SM-450 gas head to match the cam, and you have a great set up from a factory set up. The blocks are bigger in bore, the SM-450's had a 4-1/4 block bore with no sleeves, and the Ms were 4-1/8. I just built a 320 cube Super M, just added stroke, made 92 hp at 215 psi of compression. Made a solid 87 hp on ordianry Amoco Ultimate 93 octane. Hope this helps. Chad
Flogger
05-27-2005 05:29:20
The stroke is the same. Super Ms and late production Ms used a larger crank journal and thinner bearing inserts.
Mperfection
05-29-2005 06:26:45
 Re: M Vs Super M Motor in reply to Flogger, 05-27-2005 05:29:20
Is the main journals bigger or the rod journals? If the rod journals were bigger i thought about offset grinding the rod journals to fit my smaller M rods.
ChadS
05-29-2005 08:00:20
 Re: M Vs Super M Motor in reply to Mperfection, 05-29-2005 06:26:45
Both are bigger VS the M. its not enough to give it much to offset grind them. ChadS
