Roller rockers - how why?
Hooked
05-25-2005 04:52:24
Is it a big job to install high ratio roller rockers? Exactly how do they work to increase horse power? Thanks for the info.
buickanddeere
05-25-2005 07:21:05
 Re: Roller rockers - how why? in reply to Hooked, 05-25-2005 04:52:24
The roller tips also reduce valve stem side loading which causes friction ,extra heat and valve stem/guide wear.
Buzzman72
05-25-2005 06:25:14
The roller pivot uses needle bearings, and it reduces friction and provides a negligible power increase in a low-rpm engine. It's the high-lift function that provides the power increase, as it allows the valves to open wider, which allows more air/fuel mixture into the cylinder in the same timing event. Providing your intake ports and valves are large enough to take advantage of this, with more air-fuel mixture in the cylinder, you get more "bang" every time the spark plug fires. In combination with a bigger bore or longer stroke or higher compression [or a combination of the three], the horsepower increase can be significant.
It all depends upon whether your engine is configured to take advantage of it. On a stone-stock engine, high lift roller rocker might improve performance some, but not nearly as dramatic a difference as when the engine has other modifications.
Hooked
05-26-2005 05:54:20
 Re: Roller rockers - how why? in reply to Buzzman72, 05-25-2005 06:25:14
The tractor is a 1945 A with a power block bored .125 over, heisler head and JD 60 push rods.
Sounds like the roller rockers would work well with this tractor
