Would it fit?
Jak
05-24-2005 14:09:49
Is there enough room for a 5.9 Cummins to fit between the framerails of an 88 oliver?Wouldn't that be a hoss if it would work?I guess one would have to pull with the v 8's or exhibition only.I seen a 4cylinder Cummins turbo in a Super M Farmall that was a stout dude,sounded good too.It was kinda strange to hear a Super M whisteling and blowing that much smoke.
Hillbilly Hooker
05-24-2005 20:24:50
 Re: Would it fit? in reply to Jak, 05-24-2005 14:09:49
Hey JaK, I have just what you need , 1800 motor with a turbo. I will sell you the motor and give you the tractor to go with it. It is in a 880, good runner and sounds good also. H.H.
Jak
05-25-2005 06:41:46
 Re: Would it fit? in reply to Hillbilly Hooker, 05-24-2005 20:24:50
Now your talkin!
Jeff Oliver
05-24-2005 20:05:24
Hey Jak, I almost bet it would with a little grinding here and there. Heck the put 283 1800-1850 motors in them so why not? Might want to stick with a Perkins or Waukeshau though so you can still pull in Super farm... same brand engine as tractor ya know..LMAO!!!!
Personally I think if your going to go that that trouble just go ahead and get you a 3208 Cat with twin Turbos....naw on second thought if you do you will never get Kelsy off of it!!!! LMAO!!!!!
4x4 Truck Fan
05-25-2005 06:05:26
 Re: Would it fit? in reply to Jeff Oliver, 05-24-2005 20:05:24
I know where there is a 3208 Cat in a F-8000 Fire Truck.
1468 farmer
05-25-2005 05:19:47
Jeff I got a 295hp 3208 in a salvage terra-gator that has 1800 Oliver wrote all over it, then will see if you can get Brandon off of it LMAO!!! good luck this weekend. Jak I got a good running 5.9 when your ready
Jeff Oliver
05-25-2005 12:59:34
 Re: Would it fit? in reply to 1468 farmer, 05-25-2005 05:19:47
I think I can get him off of it although I am sure I would have to break out the BIG STICK to do it! And if I turbo'ed it even that would work! LMAO!
Jak
05-25-2005 06:39:29
This was just a concept but reality is lookin pretty good.I was wondering if someone had already done this.
Jeff Oliver
05-24-2005 20:08:41
One other thing on that. You might need a little machining work done, ya know any good machine shops around? I have heard there is one over in UC who has an owner that fools with old tractors but I am not sure about the quality of the work..hahahah!
