Farmall H spoke wheel weight vs. cast hubs
jhb
05-23-2005 12:33:08
I have a Farmall H with cast center and drop center rear rims. Can anyone tell me if I replace them with spoked hubs what the difference in weight will be. I need to lose about 200 pounds. I already removed about 75. I do have the spoke hubs with rims. However, my spoked hubs have a cast center. Apparently they came cast or pressed steel. Your help will be greatly appreciated.
Danieljohn
05-25-2005 19:48:33
 Re: Farmall H spoke wheel weight vs. cast hubs in reply to jhb, 05-23-2005 12:33:08
I replaced mine with the pressed steel and saved 370 lbs. I don't think that you will save mutch with the cast spoked ones. I would suggest that you find a set of pressed steel ones bofore you go through all the work to cut and weld thim inplace.
