Sharon Tn.pull
rules
05-23-2005 08:04:32
Where is Sharon Tn.? I will come.
green deutz
05-23-2005 17:19:20
 Re: Sharon Tn.pull in reply to rules, 05-23-2005 08:04:32
how heavy are you going to pull?
thanks
jerry
Jak
05-24-2005 05:48:11
 Re: Sharon Tn.pull in reply to green deutz, 05-23-2005 17:19:20
Georges sled can go on up past 12000 if someone wants to hook.Jeff was right,7500lb is usually it for antiques but can go higher.What do you want to bring?You will get to go down the track.Holler anytime,Jack(TN).
Jeff oliver
05-23-2005 20:30:52
Usually go up to 7500 but if there is enough for a higher class they will normally add one. Also I think they are going to do a non turbo class again. Jak, help me with this one as I am not sure on it but that is what I thought I heard. hehe personally between the parades ,show, and pull it won't hurt my feelings if they don't ya know but we got the 4020 running again and would be nice to see how it did.
Jak
05-23-2005 10:19:28
Sharon Tennessee is located about 40 miles north of Jackson TN on highway 45 about 8 miles south of Martin TN on hwy 45.The pull will be at the high school football field.Come on down,Jack(TN).
Puller
05-23-2005 08:13:53
What are the rules for the Sharon pull.
Jak
05-23-2005 10:08:39
 Re: Sharon Tn.pull in reply to Puller, 05-23-2005 08:13:53
Open 6mph,farm stock 3.5 mph,super farm 3.5.Farm stock means no custom built drawbars,factory drawbars only with clevis,no weight brackets out front,factory size tires for that particular model,first gear,stock carburators and appearance,stock rear rims,and the only weights to be added to gain a class will be the FACTORY wheel weights,no wheelie bars required but are ok if you have them.Super farm:3.5 mph,weight brackets allowed with weights,wheelie bars are required,first or second gear,16.9 38 max tire size up to 6500lbs.6500 and up can have 18.4 38's.There will not be any cut tires in the super farm(not even top cuts).Open classes are 6mph allowing cut tires.Hope this helps,Jack(TN).
confuzed
05-24-2005 05:59:47
 Re: Sharon Tn.pull in reply to Jak, 05-23-2005 10:08:39
Why is open class only 6 mph?
Jak
05-24-2005 06:27:28
 Re: Sharon Tn.pull in reply to confuzed, 05-24-2005 05:59:47
The 4 and 8 mph open classes were combined to make the 6mph by the sled owner.I am sure he is willing to discuss this with you.Email me and I can give you his phone number if you would like.mine is: [email protected]
the real CONFEDERATE
05-25-2005 20:00:50
 Re: Sharon Tn.pull in reply to Jak, 05-24-2005 06:27:28
I wish I COULD COME BEAT UP ON YOU FELLOWS BUT i'M COMMITED TO ANOUNCE AT THE SUGAR FARM THIS WEEKEND. BUT I'LL BE SEEINGB YOU SOON
Jak
05-26-2005 05:57:51
 Re: Sharon Tn.pull in reply to the real CONFEDERATE, 05-25-2005 20:00:50
Well Confederate,I wish you could come too but maybe some other time.Jack(TN).
