Ridgeland Wi. Pull
Sr.
05-22-2005 15:05:34
The Ridgeland Wi. pull is May 29th, at 6:00 P.M. This is a Run what you brung pull and hope you brung enough! Truck classes also. Hopefully there will be lots of light supers there. A great holiday pull!
twister
05-24-2005 10:18:44
 Re: Ridgeland Wi. Pull in reply to Sr., 05-22-2005 15:05:34
you need 600 cubes and/or 6000 rpms to compete with these guys, really tough 460s and WD-45s
Bring more than you can.
one wheel
05-23-2005 18:38:40
is there a 4500 lb farm class?
Sr.
05-23-2005 19:53:36
 Re: Ridgeland Wi. Pull in reply to one wheel, 05-23-2005 18:38:40
Not really. the weights start at 400, and whatever tractors can make the weight(except open tractors) can pull. This not a pull with alot of separate classes. Pull was originally founded as a pull in which you could get a hook or two with your tractor and possibly get a few bugs out, if there were any. And if you placed, so much the better. It has grown over the years and now draws quite a bit of good competition. If you can make the weight of a class, come on and pull. General rules and certain safety requirements enforced, mostly in open and mod classes. Even if you decide not to pull, come and watch, it WILL be a good time!
