cam advancing on MM, maybe Allis?
MM ZTU
05-18-2005 20:36:58
I've heard of advancing the camshaft one tooth on an MM U to give it better low end power. Will this work on other tractors, such as the Allis CA that I pull, possibly giving it enough torque to pull in 2nd gear? Could this be done to any tractor as a relatively easy way to gain a little more low end torque?
Jerry Cent. Mi.
05-19-2005 04:39:05
 Re: cam advancing on MM, maybe Allis? in reply to MM ZTU, 05-18-2005 20:36:58
I believe that some of the guys are running with keys in their cams that are offset 50%.
farmall2
05-19-2005 08:02:35
 Re: cam advancing on MM, maybe Allis? in reply to Jerry Cent. Mi., 05-19-2005 04:39:05
50% OF WHAT? The only way is to use a degree wheel,otherwise you are wasting your time.
