Head bolts
FarmerSid
05-16-2005 15:39:20
Hey all! Quick question for ya all. I pulled all the head studs from the 300 block and will be ready to put them back in by the weekend. What thread sealer should I use on the end of the studs that go into the block? I have Loctite 569 on hand and would like to know if that is good to use? Also, how tight should the studs be when putting them back into the block before putting the head back on?
Cheers!
Sid
redHpuller
05-16-2005 16:48:20
 Re: Head bolts in reply to FarmerSid, 05-16-2005 15:39:20
I recommend using pipe dope with teflon,cant beat it and it wont gull the threads up if you remove them later.
FarmerSid
05-17-2005 06:43:03
 Re: Head bolts in reply to redHpuller, 05-16-2005 16:48:20
Thanks for the advice. I have some Loctite pipe dope as well so I will use that. How tight should I put the studs back into the block?
