E-85 ethanol
Andrew K
05-14-2005 12:04:43
i have heard about people running this in the tractor at a mix to give it a boost. Whats the goods about this stuff
ChadS
05-15-2005 09:21:03
 Re: E-85 ethanol in reply to Andrew K, 05-14-2005 12:04:43
Relitive to engine compression to know how much ethanol to add to your fuel. Farmalls love it, helps smooth out the JD's torque curve. IH 6's dont like it much too much octane, unless it has over 10 to 1. If you mix it right to your engine, it will give you more HP, and torque. run a compression test, then post back for the recipe. Chad
old_rust_m
05-15-2005 16:52:08
 Re: E-85 ethanol in reply to ChadS, 05-15-2005 09:21:03
I have a C Farmall with 240 lb compression. Can't find E85 but have found 99% ethonal. Tried av fuel, not enough. Running 112 racing fuel now. What do you sugest? Thanks
