about alcohol? briggs? No??
Lawnmower man
05-11-2005 06:21:53
Just wondering if you can run alcohol on a regular briggs and stratton 11 h.p. vertical shaft? If yes how? Thanks brad
Redman
05-11-2005 19:43:34
 Re: about alcohol? briggs? No?? in reply to Lawnmower man, 05-11-2005 06:21:53
double the jet size.
BUDD
05-11-2005 08:00:53
As AC said yes you can. You will need to inlarge the jet alcohol. Alcohol will also eat up aluminum. We ran go carts several years ago and ran alcohol. It ran cooler but we had to flush the system out at the end of the day and chaged the oil after two races and at the end of the day.
BUDD
AC
05-11-2005 09:23:49
 Re: about alcohol? briggs? No?? in reply to BUDD, 05-11-2005 08:00:53
Alcohol eats up aluminum? I didn't know that...
ChadS
05-11-2005 18:50:50
 Re: about alcohol? briggs? No?? in reply to AC, 05-11-2005 09:23:49
Yep, corrosive acid is left behind. Especially if it runs lean. It has to do with the different type of flame inside the combustion chamber, its a blueish burn where gas would be a yellowish burn in color. Its like a torch in there, and alcohol, makes it worse. Chad
AC
05-11-2005 06:28:23
Darn it Brad, I told you what you have to do the other day. Forget that vertical shaft stuff,, get a Cub Cadet, and let me put a V4 Wisconsin in there. But, yes, you can, IF you have enough compression, and IF you can get enough fuel through it. Remember, it takes ALOT more Alcohol to make an engine run, when compared to gas. you"ll get a 40mph lawn mower yet...AC
bradley
05-12-2005 06:04:52
 Re: about alcohol? briggs? No?? in reply to AC, 05-11-2005 06:28:23
Ok then AC we can do the cub cadet thing later but right now i wanna get that briggs goin. ive alreadyspent to much money on the briggs to just throw it all away. Or i guesss what i could do is sell all my briggs and put that towards my cub and motor. anyways talk to ya later and thanks
