tires on a M
Phil K.
05-10-2005 19:04:43
Has anyone used 16.9 x 34 tires on a Farmall M before? i have one that is mildly built and im looking for some tires that are worn, not cut, i found a set on pressed steel wheels allready. I am just wondering if i should buy them, or keep looking for a 15.5 x 38 set (max size for 38 rims). thanks
knauffj
05-14-2005 05:53:28
 Re: tires on a M in reply to Phil K., 05-10-2005 19:04:43
Why not 16.9 x 38? Or is the 15.5 the rule where you pull at? I've pulled a stock M and 400 that ran on 16.9's and did pretty good.
Phil K.
05-14-2005 05:56:13
 Re: tires on a M in reply to knauffj, 05-14-2005 05:53:28
15.5 x 38 is the largest we are allowed to pull with, we can go to a 16.9 x 34 we are just not allowed to use 16.9 x 38.
FB
05-17-2005 15:51:46
 Re: tires on a M in reply to Phil K., 05-14-2005 05:56:13
i have on a farmall M in the 4500 - 6000 class..... not good for under 5000 but there on up there pretty good for a torquey engine
