Tandem Trailor Question
Glenn FitzGeral
05-08-2005 08:10:32
Generally do most 10,000# tandem trailors have the axels set up with a center pivot? The alternative to this would be to have the shackles for each axel mounted dierectly to the frame, resulting in each axel functioning independantly. Is it satisfactory not to have a center pivot? Thanks, Glenn F.
Two Tone
05-09-2005 12:42:13
 Re: Tandem Trailor Question in reply to Glenn FitzGerald, 05-08-2005 08:10:32
Acenter pivot is almost necessary. If you have an ajustable hitch you can get by with independent suspension if you use torsion axels and set the hitch so the trailer sits leavel. You will find that the torsion axels ride and pull better than springs, also less maintenance.
tt
8npuller
05-08-2005 22:02:43
NO
8npuller
05-08-2005 22:02:42
NO
no no
05-08-2005 17:56:56
NO NO NO NO NO NO
