Wayne County Ohio tractor pull
Rules
05-05-2005 20:34:52
May 7 tractor pull where in Wayne Co.? What time to start? Plus phone #.
Thank You.
MH49
05-06-2005 04:13:09
 Re: Wayne County Ohio tractor pull in reply to Rules, 05-05-2005 20:34:52
Wayne County Fairgrounds in Wooster, Oh. start time is 10:00 am. Rules: around 1958 and older, 'Stock' 4 mph class, open tractors and a V8 Class of some sort. 20" hitch height. I believe that they start at 3500lbs and go up from there to 8500 in the stock class. Not many rules other than that. ;-) For more details call Joe @ 330-567-3417
FM
05-06-2005 12:09:43
 Re: Wayne County Ohio tractor pull in reply to MH49, 05-06-2005 04:13:09
The classes start at 3500-6500 and then there is an 8000 lb class. They also have a 4wd pickup class, too, with a 6000 lb limit. The V8 antique class is 5700 lbs with small block motor and 5400 with big block. must have blow broof bellhousing/blanket, steel or aluminum flywheel, working kill swithc, max. 18.4 tires.
Mike
