Identifying parts inside IH 300 Carb
FarmerSid
05-04-2005 07:57:49
Hey all. Got a 300U carb torn apart and cleaned up. Been reading about drilling out certain parts inside the card but am having a little trouble identifying what part is what. Is the metering stem the brass tube that threads into the center of the bowl that has 6 small holes down each side that goes down into the threaded hole? On the top flat surface the surounds that brass tube is two more brass things. One is flush with the surface and and has a hole in it and one sticks up about 1/2" that also has a hole in it. It has a slot on the top like it is for a small straight screw driver to go in. Anyone mind expaining what these parts are? I'd appreciate it.
Cheers!
Sid
ChadS
05-04-2005 17:05:03
 Re: Identifying parts inside IH 300 Carb in reply to FarmerSid, 05-04-2005 07:57:49
The brass tube that has the 6 holes along the side, dril the bottom 2 holes out, to the same size your main jet is, after you rejet the carb. Chad
