Oliver88
wannagofast
02-14-2002 06:29:18
What kind of rpm's and HP can I expect from a 88 engine?
Engine has 3 15/16 M&W pistons, ported, polished, big valves, balanced, attempted to build a good solid reliable engine. Just curious as to what the experineced pullers can turn in terms of rpm's and HP. Engine is brand new and have not hooked it yet.
G Taylor
02-16-2002 20:43:03
 Re: Oliver88 in reply to wannagofast, 02-14-2002 06:29:18
If those valves are oversize & therefore heavier with just stock springs..... .. stock redline will be getting close to valvetrain float. If the cam ramps are a ground steeper/higher than more valve spring pressure is vital.
88Man
02-14-2002 08:32:34
Have you stroked it? If not, you've got a nice Div. II project.
wannagofast
02-14-2002 08:49:23
 Re: Re: Oliver88 in reply to 88Man, 02-14-2002 08:32:34
No stroke, 1650 intake, exhaust and carb.
880 man
02-14-2002 11:39:50
 Re: Re: Re: Oliver88 in reply to wannagofast, 02-14-2002 08:49:23
I have the same setup as you only i have a hot cam(.320) instead of regular .250 and it has strong 90 horse power(keeps rippin my pto clutches up LOL)
Brad
02-14-2002 13:20:42
 Re: Re: Re: Re: Oliver88 in reply to 880 man, 02-14-2002 11:39:50
You are only allowed 1925 RPMS for Division 2 and 3 in the NATPA. Where did you buy 3 15/16 M&W pistons?
wnagofast
02-14-2002 14:24:23
 Re: Re: Re: Re: Re: Oliver88 in reply to Brad, 02-14-2002 13:20:42
Local engine builder got them for me, will have to talk to him and let you know.
880man
02-14-2002 18:28:23
 Re: Re: Re: Re: Re: Re: Oliver88 in reply to wnagofast, 02-14-2002 14:24:23
were ya from go-fast?
