ac 220 fuel pump
farmerboy76
05-01-2005 16:43:37
I pull an ac 220 in farm stock. I overhauled it, put in farm stock cam, ported head, turned stock pump all the way up, and put in bigger injector nozzles. It does well in pulls with dyno's, but in RPM pulls, I'm way outguned. I dyno 190hp, but the tractor doesn't smoke. My next step is a bigger pump, preferably one I can adjust (less fuel at dyno pulls, more at open pulls). What is a good pump and where can I get one? Need to adjust from 170hp to 300+ hp if possible.
Panhandler
05-02-2005 16:35:21
 Re: ac 220 fuel pump in reply to farmerboy76, 05-01-2005 16:43:37
If you screw the two leaf springs down 1/4 turn and bump up transfer pressure + 50 lbs you should get all the smoke you desire.
856 puller
05-02-2005 09:22:06
talk to steve at stjoes
