farmall 560
Farmall 560
04-30-2005 05:38:22
I am rebiuding my farmall 560 Diesel and would like to raise the oil pressure. does any one have any ideas how to do this. I would like to put a turbo on it soon and i thought more oil pressure would be a good thing to have. Thanks
alpha
04-30-2005 16:42:11
 Re: farmall 560 in reply to Farmall 560, 04-30-2005 05:38:22
Stock oil pressure of 35 - 40 should be fine even with a turbo . If all your clearances are tight and you have all new bearigs and your oil pump is in good shape and properly adjusted with the paper shims that come in the kit this should not be a problem.If you are still concerned you could shim up the relief valve a little bit.
