Robert's cam grind and Jerry's head
KS G puller
04-28-2005 22:02:11
Will I need to resize my rods if Jerry shaves the head .125 and the cam gets a comp grind?
Drew
04-29-2005 05:44:28
 Re: Robert's cam grind and Jerry's head in reply to KS G puller, 04-28-2005 22:02:11
Shaving a Jerry's head doesnt gain you compression because it has no combustion chamber. Your pushrods would probably come out about the right length w/ a Robert's cam because he wacks down the base circle to nothing when he grinds them which would require a slightly longer pushrod. So the two will about offset eachother.
JDGnut
04-29-2005 05:49:34
 Re: Robert's cam grind and Jerry's head in reply to Drew, 04-29-2005 05:44:28
Drew about said it all.. even with a stock cam.. there is usually enough adjustment with the stock rockers.. you just have look at the arm, to make sure it doesn't bind on the cup holder.. I have notched these.. You can also make a shim to go under the rocker arm assembly to move the entire assembly out (this is usually when you have to watch for the arms hitting the cup.)
JDGnut
LJS
04-28-2005 23:48:24
 Push rods in reply to KS G puller, 04-28-2005 22:02:11
You are asking about the pushrods correct?
