Garret turbos
Hurst
04-28-2005 12:34:18
I have done some research and found that the diesel perkins 4.236 had a garret TA31. I see that the prices of these turbos are pretty high, and I was wondering is there another turbo that would bolt on instead of this one that is either a less expensive/more common garret model or one of another good brand? I am not sure how much pressure this turbo puts out, but I am not looking at adding more than about 20 - 30 hp at the most, probably will be more like 15 to be safe. Is there a smaller turbo that would be better suited for my needs and still bolt onto the manifold and hook up ok (and less expensive)? Thanks for your help. Also, are garrets good turbos? Anything else I need to know about them?
the preacher
04-28-2005 18:36:13
 Re: Garret turbos in reply to Hurst, 04-28-2005 12:34:18
garret turbos are one of the best.holset also makes a great one. try calling kelly nobach at michigan turbo.616-531-5126 i used to run the shop at a trucking company, and we used their turbos on caterpillar 3406b's and c-15's.i could get 35+ lbs. of boost, and turn 425HP into 550 or 600HP with the proper fuel rate adjustments.
