how many rpm's is too much
Chris Brown
04-21-2005 18:40:10
I have a question or two. I have 2 560 IH's one gas and one diesel. Both are completley stock internally with the exception of the gasser with a combine governor and carb . Both tractors will rev way above the factory settings. Is there any rpm restrictions in (what they call it here) "out of the field class". Last year there were some Olivers that sounded like they were turning up around 5000,my gasser will turn out 3500 and the diesel governs out at 2800 with a little load.
buickanddeere
04-22-2005 13:45:54
 Re: how many rpm's is too much in reply to Chris Brown, 04-21-2005 18:40:10
Double the rpms and the centrifical stress increases four times. Triple the rpms and centrifal force and stress is increased nine times.
ChadS
04-22-2005 17:05:45
 Re: how many rpm's is too much in reply to buickanddeere, 04-22-2005 13:45:54
And if the engine/flywheel has not been apart and retoruqed recently, Id keep it under 20% over rpms. Chad
Redman
04-22-2005 05:12:35
the gasser would be fine here in MN,but if the diesel has a turbo some of them boys will lay on the ground kicking and screaming!
jpl
04-22-2005 04:46:11
Chris, i belong to ohio antique pullers and our rules are 10% over stock rating, not sure about some other clubs, you can go into usapullers.com and read the rules at princton ind pulls. i am sure you will get some other feedbacks.
