ford 900 pulling tractor
david futrell
04-20-2005 20:19:47
could anyone out there give me any information on how well ring and pinion holds up on 900 rearend also im going to be pulling with 38 inch tires on rear anyone outhere tell me what size tires and rim combination works good on these tractors the tracks im going to be pulling on is very hard . ive heard some say ring and pinions hold up great on the 900 series but ive also heard they dont all information would be helpfull thanks
Floyd
04-21-2005 19:18:13
 Re: ford 900 pulling tractor in reply to david futrell, 04-20-2005 20:19:47
You need to give the drop-axels some suport. There are two large bolt holes on each ham. Make bracing and tie it all together up under the belly of the tractor where you find two 5/8 bolt holes. Make a large (a) frame. I have twisted the drops of my 900 on good track. 65hp will do that.
david futrell
04-21-2005 20:16:58
 Re: ford 900 pulling tractor in reply to Floyd , 04-21-2005 19:18:13
floyd is there any chance u could send me a picture or explain in more detail what type of channel tubing did u use what steel did u use what length are your braces do they intefere with your rear weight bracket are pulling with stock drawbar what length is your drawbar how many weights u using on the front i believe my tractor is going to be about 65 horse too any other help would be apreciated first time puller
