Ouch!!!!
JDGnut
04-20-2005 19:42:51
third party image
I guess I was a little wishfull on the head gasket... ChadS.. I guess I'll be waiting on the gasket..
JDGnut
ih460puller
04-21-2005 21:18:10
 Re: Ouch!!!! in reply to JDGnut, 04-20-2005 19:42:51
Did dad ever tell you about the JD 60 we built with 70 pistons, it did the same thing. Still have the block somewhere. Are yall coming to PLains this weekend? Mike
JDGnut
04-22-2005 05:45:40
 Re: Ouch!!!! in reply to ih460puller, 04-21-2005 21:18:10
Yup... When it first broke... I sure was thinking of him and the 60... He had told me about... As you can see.. I'm not going to make it.. lol.. GP was talking about bringing a G.. but I haven't talked to him in a few days... JDGnut
JD720
04-21-2005 19:44:19
Just out of curiosity how much compression were you running ? I am getting ready to put mine together with a sleeved block I hope mine don`t end up the same way .
JDGnut
04-21-2005 19:50:30
 Re: Ouch!!!! in reply to JD720, 04-21-2005 19:44:19
I wouldn't worry a bit with a sleave.. (at least not blowing out like this) I'm looking for someone to sleave this block.. JDGnut
ChadS
04-21-2005 11:10:53
YEOWW!! Bout shove a cat through that hole! Looked as if it was cracked before,,,, and let loose. Looks thick enough,, but who knows,,, all that area to compress, weakest links will be found real quick. Id bore that cyl, and make a repair sleeve if possible,,, does powerblocks have sleeves? find someone to makes a sleeve, bore the block, to fit the sleeve. Hard block??? its not that bad of a repair if you can get sleeves made. Id say your looking at the cost of the repair, would be as much as the cost of boring out another block,,, but, I think the sleeved engine would be a stronger set up for the time and effort., and repairable if the sleeve lets loose. Drop in a new sleeve and go again! Id bet that was a stress crack from the outside in the water jacket, rust pin hole just got bigger?? Like I said, Im on stand by for the gasket,, but looks like the gasket is just fine!!! That's good news I guess,,,,, LOL. Whatcha gonna do?? Chad
JDGnut
04-21-2005 12:18:10
 Re: Ouch!!!! in reply to ChadS, 04-21-2005 11:10:53
I like Mike's Idea.. put a little wax paper on the inside.. and fill the block with JB weld... LOL.. I really wasn't that worried about that area of the block.... because this block was running at one time in another tractor.. but that's the way it goes.. Not sure if I'll have it sleaved all the way down.. or just the counter bore.. All the way would make it right.. and solid.. as long as the sleave wouldn't move down.. I'm a little worried about them boring to install a new sleave, because there won't be anything left if they try to bore and then press in a sleave.. If I just go with the counter bore.. the rings don't travel that far up.. and the piston is narrower.. so it can actually stick into the cylinder.. this would also help with the sealing surface at the head gasket... The other is that a local shop could do the counter bore.. and I don't trust them to sleave the entire block that is that thin... I'd have someone that is more specialized do that.. Worst comes to worst.. it might get the crank pulled too.. and get small 45?cid engine to get me by... (I could probably have that running in a few days... but why step back.. unless I have too.. )
We'll check the rods and crank today... JDGnut
gpuller
04-21-2005 07:33:19
Looks likes it's time for Jerry's 7 1/2" block and pistons. Go big or go home!
Earl-IL
04-20-2005 20:33:09
Did it take water than hydraulic???? Earl
JDGnut
04-20-2005 20:46:53
 Re: Ouch!!!! in reply to Earl-IL, 04-20-2005 20:33:09
Earl.. I don't think so... It had been running without loosing coolant.. and it was just a big bang... I was a little afraid that it was more than the gasket.. When it blew.. it blew the upper and lower hoses off... I pushed the coolant out and let it sitt for a few days.. and then started it with only the #2 plug in.. and loaded it on the trailer and hauled it home.. (dyno is at Dad's place.) When it was running with the #1 plug out.. I could see air going in and out of where the upper and lower hoses attach..
I havent found the piece yet.. but there were no marks on the piston.. so I'm guessing its in a water passage somewhere.. I'll look tomorrow.. JDGnut
Earl-IL
04-21-2005 10:04:46
 Re: Ouch!!!! in reply to JDGnut, 04-20-2005 20:46:53
Your block didn't appear to be bored big ,I noticed the counterbore in the front?Or did they put it back on the rebore? Earl
JDGnut
04-21-2005 12:23:49
 Re: Ouch!!!! in reply to Earl-IL, 04-21-2005 10:04:46
Earl.. The counter bore has always questioned me on this block.. because its still in there.. This block was this bore when I got it.. I was always worried about the head gasket because of the counter bore... All I'll say about the bore.. is that its bigger than the counter bore leads it to be.. All I can guess is that someone long before me put the counter bore in there.. This is a Long G (Unstyled G) block.. and the only one I have... so I'll have to fix it.. I have a handful of the late G blocks.. JDGnut
Mike n Mo
04-20-2005 20:25:06
Nuthin a little JB Weld won't fix! I guess 50 years of rusting away was just a little too long. Mike
