hey farmall guys
the preacher
04-19-2005 19:36:13
would it be possible to put pistons and liners from an M into an H block? just wondering. don't have any specs on engines. would i have to have the crank stroked, or rods modified, or is it as simple as boring out block? thanks
ChadS
04-20-2005 09:11:57
 Re: hey farmall guys in reply to the preacher, 04-19-2005 19:36:13
No, not the H block, mite be able to with a C-175 block (350) Those seem to have a bit more room in the block and can hold a bigger bore easier VS the H block. You wont have a sleeve flange in the top of the block, would work as a kinda a dry sleeve insert set into the bored out 350 block, and hard block em in place, then finish machine work. your looking at boring out the block to 4-1/8, it can be done, sleeves will be touching each other though,,, Ive got a 350 block set up to run 4 inch, has aftermarket sleeves, and they are .130+ thick side walls, and the sleeves are just barely apart from each other. Not as simple as just boring the block, but,, its possible. ChadS
