Cement tractor pull-shepherd
cementpuller1
04-19-2005 19:09:02
April 22, and 23 (friday and saturday) there is a pull in Shepherd Michigan on cement. THe lawnmower pull percentage pull starts at 11:00, so weigh ins are probably starting at 8. The 9500# class will start about 30 minutes to 1 hour after the lawnmowers get done. No year limit, no tires wider then 30". drawbar 20" high, 24" from the center of the axle. Saturday pull starts at 11:00 also, weigh ins DONE at 10:45. 5000#, 6000# non-readial 18" limited (no tires LARGER or wider then an 18x38)class, 6000# regular class, and a 7500 lb. class. 20" high, 24" behind, wheelie bars manditory. no jumping classes as it has been for the last couple years. hope to see ya's there.
2 Cylinder
04-20-2005 06:26:49
 Re: Cement tractor pull-shepherd in reply to cementpuller1, 04-19-2005 19:09:02
Pray for good weather for Saturday! The forcast shows a very cold and wet day. Hopefully the forcast will change. Did I read your shedule right, your running the big tractors (9500#) on Friday instead of Saturday? The big tractors put on quite a show, and get wild at times. This pull kicks off the pulling season in the Central/Mid Michigan area. This is a pull to get you excited for the pulling season. Good place to pull and be a spectator also. Good luck with the pull!
