What do you think about this?
Jim M
02-12-2002 09:14:25
I am wanting the NATPA to allow me to pull my Case 500B built in 1958 in Class 2. Right now the answer is NO. But. It is the same as a 1957 Case 351 with only cosmetic differences in sheet metal and front casting. If they allow 730 J/D's pull because they say they are the same as 720 J/D's except for cosmetic then shouldn't I be able to pull my 500B. Jim
shoe
02-13-2002 20:35:02
 Re: What do you think about this? in reply to Jim M, 02-12-2002 09:14:25
They are just afraid that the 500 will out pull
the JD's. Keep trying, maybe they will let you in
that class. The 500 is quite the puller from what I've seen of them. good luck.
Up north puller
02-13-2002 19:25:12
If it was a JD or IHC they would.
chris
02-12-2002 10:02:09
I don't have a problem if what you say is true but you should have to wait till next year as they made the 30seris deere's wait till the start of a season
Paul
02-12-2002 17:04:45
 Re: Re: What do you think about this? in reply to chris, 02-12-2002 10:02:09
Don't go there. I can't pull my 880
Disturbed
02-13-2002 17:48:35
 Re: Re: Re: What do you think about this? in reply to Paul, 02-12-2002 17:04:45
What is their problem with an 880? Don't they like pressurize mains? They pull Cockshutts with pressurized mains.
