Jd not running right
Jc
02-12-2002 08:50:56
My d is not running like it should it smokes alot of white smoke out of the right cylender. it also smothers down when is is just running. What is wrong with it. It has new rings they are not set yet could that be part of my problem. Thanks JC
Deere Puller
02-12-2002 10:49:11
 Re: Jd not running right in reply to Jc, 02-12-2002 08:50:56
If you're pushing white smoke, she's taking on water from someplace (head, block, gasket). If you had the head & block both magnafluxed and pressure checked, the problem is most likely in the gasket. If you haven't checked the block / head, you may be forced to do so. I am presuming that you are not using the water injection valve, since few have working ones in the first place.
