Thanks
farmerjim
04-18-2005 19:50:53
Just wanted to say thanks to you guys for the help. But as of right now I am at a stand still once again. I took the injectors out of the tractor tonight and tested them. 4 out of the six "let go" at 3000 psi, the other two were a different story. About 300 to 400 psi they started to leak out the nozzle and when they did finally let go the whole way, it was a stream of fuel and not atomized at all.
So I am back to sqaure one. I am sure two bad injectors could really make a difference on how much white smoke the tractor is putting out.
Just wanted to say thanks and I am sure I will be asking plenty of more questions before I get this problem figured out.
Redman
04-19-2005 10:29:13
 Re: Thanks in reply to farmerjim, 04-18-2005 19:50:53
midwest diesel injection services,ft dodge IA.
talk to lee,he will be cheaper than hyper and you will get it when he says you will.
i'm not at the shop so i don't have his number,as i recall the last set i had him rework cost around $40 a piece.goog luck.
