Morrow County Fair Tractor Pull Sept. 4th 2005
Ohio M Puller
04-12-2005 11:36:16
2005 Morrow County Tractor Pull
Hook Fees $20
Prize Money 1st - $100 2nd - $75 3rd - $50
4th - $30 5th - $20
Weight Classes In Order Of Run:
4000 9000 5000 10500
6000 12500 7000 14000
General Rules:
1 All drivers must be at least 18 years old
2 Only Gas, Diesel, and LP Factory Equipped tractors allowed
3 No Funny Fuels, Nitrous, Alcohol, Water Injection, or Propane Injection Allowed
4 All tractors are to run the Suggested High Idle for their model with an allowed 20% over
5 NO CUT or GROOMED Tires in any way, IF ALTERED NO HOOKING !!!!!
6 Any Rubber Tire Size Allowed Radials Welcome, NO STEEL LUGS or Dual Wheels
7 Two wheel drive tractors only however, front wheel assist can pull as long as 4WD is disengaged
8 Drawbars are not to be shorter than 18 inches from center of axle to hitch point
9 Drawbars are to be no higher than 20 inches from ground to top of hitch point
10 Hitches must be ridged in all directions
11 No part of drawbar to be higher than hitch point
12 Hitches must have a 3 inch opening and be made of at least 1 inch diameter material
13 Clevises are allowed as long as they are a twisted type and comply with rule number 12
14 NO STRAIGHT CLEVISES ALLOWED
15 Engines must be of stock appearance as well as cylinder block, heads, and manifolds
16 Single fuel pump and/or injector, carburetors of original manufacture and design ONLY!
17 NO Airplane, military, or non agriculture carburetors Allowed!!
18 Classes from 7000 and lighter will run a 5mph speed limit
19 Classes from 9000 and heavier will run a 7mph speed limit
20 Single turbo tractors allowed in classes of 9000lbs and heavier only
21 Speed will be monitored on sled and all pullers will be allowed 2 beeps the 3rd beep puller is D.Q.ed
22 Wheelie Bars are HIGHLY recommended but not required
23 A 2.5 pound or larger Fire Extinguisher is HIGHLY recommended but not required
24 All weights must be secured
25 No weight allowed past 12 feet from center of rear axle to furthest point forward
26 Rear weights are to be no further than 18 inches past furthest point of rear tires
27 Rear weights are not to obstruct hitching ease to sled
28 Any loss of any object from tractor while hooked to the sled will result in a Disqualification
29 Side shields allowed but must be easily removable
30 All pullers pull at own risk to damages of their equipment
31 Any or All damages are pullers responsibility not the promoters
32 All Tractors must weight in before hooking to sled and once in staging area no changes maybe allowed without reweighing
33 No Riders and a Safe Speed will be enforced in the pit area
34 Class Closed once the first puller of that class hooks to the sled
35 All pulls will start with a tighten chain. NO JERKING OF THE SLED
36 Pullers must stay seated for the entire length of the pull, no bouncing in the seat
37 Hands must be on steering wheel, throttle, hand clutch, and or hand brake for entire length of pull
38 All drivers are allowed 2 tries to pass the 75 foot mark once past no restarting
39 Puller must pass 50 feet to qualify for premium except for tie breakers or pull offs
40 First puller of each class is the test puller with the option to drop and come back in 3rd position
41 $500 protest fee with Protester's tractor inspected first!!!!
42 Judges and officials decisions are final... including situations not covered in these rules
43 No Drugs or Alcohol Before Or During The Pull
44 Each tractor will be given a visual safety check. Any fluid leaks or items that jeopardize safety will result in disqualification.
45 Drivers are to watch the flagman once tractor is hooked to sled. Flagman is in control. Failure to follow his direction will result in disqualification.
46 Tractor (not sled) must stay within boundaries or be disqualified
47 Classes with less than 8 entries will only be paid out to top three places.
Ohio M Puller
jd b puller
04-13-2005 20:26:56
 Re: Morrow County Fair Tractor Pull Sept. 4th 2005 in reply to Ohio M Puller, 04-12-2005 11:36:16
That isn"t still a closed county pull is it?
Thanks, Ray from Mt. Gilead.
jd b puller
04-13-2005 20:24:46
Ohio M Puller
04-14-2005 09:16:53
 Re: Morrow County Fair Tractor Pull Sept. 4th 2005 in reply to jd b puller, 04-13-2005 20:24:46
This pull is open to all. I sure hope to see new faces and tractors this year. I did get us a little earlier start time at 6:30 as well as paying alittle deeper in the classes. Thanks for the interest and see you there.
Ohio M Puller
Heavy Puller
04-14-2005 08:55:54
Hey is this one open to the world? or just the August pull.How can you pull there if you live in Henry County?
jd b puller
04-15-2005 19:04:54
 Re: Morrow County Fair Tractor Pull Sept. 4th 2005 in reply to Heavy Puller, 04-14-2005 08:55:54
I am from this area (Morrow County) but now live in NC. I"d like to come, but I can"t do it for just one hook (4000 lb). Anybody out there have a list of the Ohio county fairs so that I could hit 4 or 5 pulls that weekend?
Thanks, Ray
Ohio M Puller
04-14-2005 09:18:42
Both pulls are open to the world.
Ohio M Puller
P.S. Funny Warren
Heavy Puller
04-14-2005 09:53:10
 Re: Morrow County Fair Tractor Pull Sept. 4th 2005 in reply to Ohio M Puller, 04-14-2005 09:18:42
No problem just wanted to make your day more exciting, isn't that my job?You have any 14.9x38s you want to move call me?
