Chad S. Web site?
Semo H
04-12-2005 09:28:09
What is his web site address. Also tried to put a curve kit in my Farmall H and there is alot of difference in the springs, from the stock ones to the GM HEI springs the HEI springs are alot smaller and shorter than stock. I'm afraid they might straighten out and come off..
FarmerSid
04-12-2005 10:19:15
 Re: Chad S. Web site? in reply to Semo H, 04-12-2005 09:28:09
Link
That is his site address. I just got a recurve kit for my '51 H but have yet to install it. I think that the springs being smaller is the point of the retrofit. You want the weights spread out sooner as Chads has said the stock springs will not let the weights spread out through out the entire RPM range. They won't begin to spread till way past factory RPM setting. I could be wrong but thins is how I understand it from the searching I have done here. Do you have any pictures of the installation of the springs?
Cheers!
Sid
