Chad .S need help on carb
farmall H Pulle
04-10-2005 20:20:14
I drilled the jet out on my H and now when i put it back togher in leaks gas out of the carb. Would the flot be sticking or do i have something not set right?
Also do you have a re-curve kit for a farmall H if so how much would you want for one.
Thanx mIlEs
ChadS
04-12-2005 07:08:09
 Re: Chad .S need help on carb in reply to farmall H Puller, 04-10-2005 20:20:14
Big carb or small carb? If its the big carb, float may be hitting the side of the bowl,, small carb, mite have a piece of dirt, or the float is bent. if the fuel level is too high, from the flaot being set wrong, gas will run right out of the metering stem and can siphon the tank dry over time. Chad
