FORD TRANSMISSION
OLIVER NUT
04-10-2005 18:57:57
I have a 1989 F250 ford diesel pickup the transmission doesn't last, the pan gets full of filings and its junk. six diffent shops have overhauld this transmission still no luck. can anyone help, or have a suggestion on what to do?
Flogger
04-11-2005 09:58:32
 Re: FORD TRANSMISSION in reply to OLIVER NUT, 04-10-2005 18:57:57
The E4OD is notorious for cooking torque converter clutches especially behind diesels that are loaded heavy. If you you have 3.55 rear gears it really aggravates the problem. Switching to 4.10s will usually help a lot. Somebody in the aftermarket probably has a converter that will live. The converter is the weak link in the E4OD
B PULLIN
04-10-2005 19:19:47
BUY A REMAN TRANSMISSION AND TURN YOUR DUD IN FOR CORE VALUE. IF IT HAS HAD THAT MUCH TROUBLE GET RID OF IT!
OLIVER NUT
04-10-2005 19:40:40
 Re: FORD TRANSMISSION in reply to B PULLIN, 04-10-2005 19:19:47
The transmission is a E4OD and it has been a diffent core and a REMAN. THANKS
superih
04-12-2005 09:52:37
 Re: FORD TRANSMISSION in reply to OLIVER NUT, 04-10-2005 19:40:40
E4OD is a very durable trans. Yes the torque converters will go out but it is usually because they were overheated due to driving styles. Ford did not put big enough trans coolers on the trucks. Sun Coast makes the best replacement torque converter. There are different levels of performance you can buy and they are bullet proof. They don't give them away, expect around $1300. They also have the best rebuilt transmissions for around $3000. Anyone that hauls loads with an automatic, especially if it is alot of stop and go should have a trans temp gauge. It is amazing how quickly an automatic can heat up under load in stop and go conditions. Also, if you are replacing transmissions make sure to flush your cooler lines. The same grit in the trans oil that ruined your trans is still in the cooler and will go right back into the new trans unless flushed.
mjs in mo
04-10-2005 20:20:20
i had a 1990 ford with a E4OD they would last from 3 to 30000 miles and they all came from ford as remans i went through 4 or 5 before i switched trucks.
