MM heads
Dudley409
04-08-2005 10:39:12
I ve had an idea i want to make center drilled heads for my UB. This would be Hemi style with the spark plug in the center of the combustion chamber hoping to make a little more power. If anyone has done this or heard of it any advice would be great. Thanks
answer
04-08-2005 19:06:14
 Re: MM heads in reply to Dudley409, 04-08-2005 10:39:12
Your idea is not necessary. I think you are confusing the center fire idea of the deere's to the MM head. The deere's plug was on the side of the block on a maximum of a 6.75" bore of a D. When the bore was increase way past that the plug was no longer effective at firing the combustion chamber that was bigger. On the MM. The plug is near the center of the chamber already. If you want to help the MM. Figure out how to strengthen the center main.
LW
04-08-2005 19:16:55
 Re: MM heads in reply to answer, 04-08-2005 19:06:14
Center main ain't a problem the bearing design is.
Future MM puller
04-09-2005 06:05:10
 Re: MM heads in reply to LW, 04-08-2005 19:16:55
Just curious, what's up with the center main and what's needed to correct the bearings, haven't heard of these issues before, Gerald
craigk
04-08-2005 19:26:57
How do you fix that?
LW
04-09-2005 06:50:46
 Re: MM heads in reply to craigk, 04-08-2005 19:26:57
[email protected]
