Engine idling too high on JD A-govornor problem
a puller
04-07-2005 11:45:21
tear apart the governor(not jed bush)haha. Had a 51 A do that and under a load, it would amost die. the govorner weights wouldn't work when under a load, the shaft wore down and wore a groove in the brass slide deal that opperates the govorner. put a couple washers under it and fixed everything, and it works fine now. I'd bet its in the governor if i had money to bet with..HAHA...
