Electric fuel pumps ?????
Ohio puller
04-02-2005 12:58:51
Ok pullers, I need help with this one!!! If pulling a basic stock gas tractor why would you need an electric fuel pump unless carb too big for engine or ????? There is one guy who pulls an Farmall M with a 450 engine and he says it will not run right without it. Another guy has a Cockshutt 40 with a 262 engine and claims the same thing. These engines are completely stock with no modifacations and pull at 10% to 20% over stock RPM for the make and modle of tractors. I beleave they are running too big or wrong carb or have carb screwed up. Would like to see what other views and opinions are. Maybe I'm off track and they are right or maybe they are shall we say, not stock and maybe stretching the rules !!!
buickanddeere
04-03-2005 11:47:41
 Re: Electric fuel pumps ????? in reply to Ohio puller, 04-02-2005 12:58:51
If that engine is bored,stroked and souped to the ears. And it likely is. Fuel demand will be much higher. Or they maybe burning that 85% ethanol auto fuel to make extra HP. The stock sized needle/seat may flow enough fuel via gravity at stock fuel rates. With larger main jets, perhapes a few extra psi forcing fuel in from a 4 psi pump is required. In order to keep the fuel bowl up to the proper level? A leaned out engine looses power, runs hotter and is more prone to detonate.
705puller
04-03-2005 10:58:13
So if your using a rubber line for fuel would it be possible to create enough suction to suck the line together???
Drew
04-03-2005 07:57:51
Have they tried just using bigger fuel line and non restrictive fittings?
BUCKMASTER
04-02-2005 19:05:02
THEY ARE FULL OF SHT THEY SHOULD BOTH RUN WITH OUT FUEL PUMPS UNLESS THEY HAVE DOWN DRAFT CARBS THEN THE CARB IS HIGHER THEN THE TANK NOT STOCK PEOPLE WILL TELL YOU ANY THING IF THEY THINK YOU WILL BELIEVE THEM TO MANY BULL SHTERS OUT THERE THE WAY I SEE IT
halfbreedm
04-02-2005 20:31:29
 Re: Electric fuel pumps ????? in reply to BUCKMASTER, 04-02-2005 19:05:02
well buck i guess im full of sh*t then i have a farmall m with a 450 carb and on a hard pull it dont get enough fuel without the pump on it and it is a stock motor
no BS
04-03-2005 10:43:11
 Re: Electric fuel pumps ????? in reply to halfbreedm, 04-02-2005 20:31:29
Thats right you are full!!!!! of sh$t,Just like He said!!!
