Hard blocking
Pawn
03-28-2005 19:16:09
What kind of material do you us to hard block something. Will it expand at different rates than the sleeve will.
dan m
03-28-2005 19:27:59
 Re: Hard blocking in reply to Pawn , 03-28-2005 19:16:09
most of the hard block (brand name). are a mortor or concrete mix with iron granuals mixed in. they recomend more piston clearence with it so i assume it doesn't allow the sleeve to expand as much. i won't use it. just keep 1/8" wall thickness on sleeve and run coolant. it's much more consistsant and reliable.
Pawn
03-28-2005 19:48:59
 Re: Hard blocking in reply to dan m, 03-28-2005 19:27:59
Will 1/8 thick sleeves hold up to being stroked.
farmall2
03-29-2005 07:38:15
 Re: Hard blocking in reply to Pawn, 03-28-2005 19:48:59
NO! You must hard block at least half way to hold a stroker's extra side thrust on bore. Hope this helps
stroker 88
03-30-2005 20:03:00
 Re: Hard blocking in reply to farmall2, 03-29-2005 07:38:15
bull! ran a 5 3/4" stroke with 7" rod 1/8" wall thickness on sleeve. 4 1/8" bore ran 3 years sold tractor and it is still running. sleeves haven't been a problem wrist pins and pin bushings sure do take a beating at that rod angle though.
CrazyAllis
03-29-2005 19:14:27
If you get the rod to stoke ratio right and use the correct skirt design piston you should never have to hard block a tractor engine.These hairbrained ideas that are propagated by individuals lacking in technical training with no idea of the principals of mechanical engineering serve as a constant reminder of; if you don't know what you're doing, ask someone that does,NOT someone that THINKS they do.
stroker 88
03-31-2005 17:52:40
 Re: Hard blocking in reply to CrazyAllis, 03-29-2005 19:14:27
yeah, and without hardblock we can run the tractors more than 5 minutes without burning them down. also if we ever need to we can still replace the sleeves. just like a stock one.
farmall2
03-29-2005 20:14:28
Where are your engines and how are they doing? If you had a clue a shorter rod in low rpm engine speeds up the piston. Like running higher rpms but you arn't. You are talking race car engines. There a longer rod gives you more dwell on tdc and gives fuel time to burn thus more hp at high rpms.
clarence barenie
03-29-2005 19:55:51
 Re: Hard blocking/crazyallis in reply to CrazyAllis, 03-29-2005 19:14:27
Since you know so much, I must ask, what is the best ratio to use in a 4 cylinder gas tractor pulling motor !
Next question ? what do you do with a connecting rod that, to maintain ratio is sticking upside the head !
PRETTY POWERFULL STATEMENT HERE, could you explain
stroke too ratio and the beneifit or lack their of !
I'm starting at 1.91-1.00 going to (with stock rods) 1.60-1.00
thank's for your input !
Flyin Farmall
03-29-2005 07:57:28
I know of quite a few stroked engines that don't have hard-block,and do just fine.You can solve the side thrust problems,with using different length rods.
