mm main bearings
minnie ub
03-28-2005 17:46:18
anyone know the clevite # for the main bearings for a G crank in a ub block.
Earl-IL
03-28-2005 17:57:59
 Re: mm main bearings in reply to minnie ub, 03-28-2005 17:46:18
Main Set # is MS-531P std,- .010,-.020
MM 3535
03-29-2005 17:47:45
 Re: mm main bearings in reply to Earl-IL, 03-28-2005 17:57:59
Do you have a source for the clevite Mains for a MM? the last few times i wanted some no one could find any.
Earl-IL
03-30-2005 07:26:28
 Re: mm main bearings in reply to MM 3535, 03-29-2005 17:47:45
MM3535, I usually go right to the manufacture if a jobber or warehouse don't have what I need.They can tell you if they are still making the bearings and what warehouse they are located in. Clevite Engine Parts--735-975-4777 set number MS531P... Federal-Mogul 284-354-7700 Set # 4163M Customer Service. Save old brg shells they can be rebabbited and then line bore if you can no longer find brgs.Earl In Illinois
