9 bolt hubs for GVI and 705's
jonny
03-27-2005 18:07:25
How are the pullers putting pressed steel wheels on their GVI's and 705's? Are they using a hub off of a different model or are they making weld on hubs? Thanks
Dieselbear
03-28-2005 09:34:02
 Re: 9 bolt hubs for GVI and 705's in reply to jonny, 03-27-2005 18:07:25
A set of hubs off a F30 will fit just rite. Just drill for the 9 bolt pattern. The ones I'm using weigh 40 lbs each
Lamont
03-27-2005 19:43:24
Try catching a guy on here that goes by Hillbilly Hooker. He can tell you all you need to know about that.
REDWHEELS
03-27-2005 19:29:38
They are making weld on hubs or machining down the original hubs and making them. There was no 9 bolt hub for those tractors made oem.
