MSD box on Farmall H
Semo H
03-24-2005 15:44:36
I have a H with 350 parts in it,nice cam,electronic ignition, and a 300 carb. My question is would a MSD box improve the performance. If so which MSD box would it be. Later on I plan on having a stroker kit put in also, so could I use the same box or not. Thanks
BUCKMASTER
03-24-2005 16:45:33
 Re: MSD box on Farmall H in reply to Semo H, 03-24-2005 15:44:36
YOU NEED A 6200 MSD BOX IT IS 6 A YOU CAN BURN SO MUCH MORE FUEL IT IS WELL WORTH THE MONEY EASY TO HOOK UP
Lenny
03-24-2005 16:20:54
The improvement may be very small unless you are running a lot of compression. You may benefit more from an electronic ignition trigger source along with the MSD.The stroker crank will have no effect on the MSD box.
