MM UTS w/ lp intake
Texas Red
03-23-2005 03:19:54
I put an LP intake and a set of zoomys on the Uts, I acts like it realy wants to pull, But.... seems to be a little cold natured now. idels a little rough. is there something in the timing to work on after the LP intke. Is there someone who has an LP intake on there UTs with tips on tuning?? thanks for the help TR
LW
03-24-2005 05:07:26
 Re: MM UTS w/ lp intake in reply to Texas Red, 03-23-2005 03:19:54
Your idle left you when you put the 4 individual pipes on it.
Andy2
03-23-2005 19:53:42
Depends on which intake you are running. If you have stock displacement,(283) and are running the 670 style Y shaped manifold, you may be getting some fuel seperation at idle speeds because there is less turbulance. What are Zoomys?
Texas Red
03-24-2005 03:30:27
 Re: MM UTS w/ lp intake in reply to Andy2, 03-23-2005 19:53:42
The LP intake is T shaped, The zoomys are four exhaust pipes, kind of like headers, sure makes the old bark.
minnie ub
03-23-2005 17:43:04
are you stock bore and stroke. when you say it acts like it wants to pull are you putting it on dyno.
Texas Red
03-24-2005 03:33:58
 Re: MM UTS w/ lp intake in reply to minnie ub, 03-23-2005 17:43:04
the tractor is stock ( for now) I have no way to get to a Dino around here, we put it on a 12 point chisel and socked it just about as deep as it would go. It realy wrinkles the tires and flots the front wheels.
