UB Moline
N.M. Puller
03-21-2005 18:57:13
Here goes will a stock UB pull very good with 18.4X38 tires?Has less than 100 hrs.on overhaul.Planning to go modifid.Bigger intake, 20" hitch.Runs on lp.I can get a real good deal on the 18.4X38 Firestone tires.I'm hoping to get some imput from ya'll since new to pulling.THANKS
minnie ub
03-22-2005 17:20:03
 Re: UB Moline in reply to N.M. Puller, 03-21-2005 18:57:13
18.4 are to big for stock but 15.5 or 14.9 would work great. if you go bigger intake like maybe a peterson i don't know if stock stroke and bore will be good enough. try a 670 manifold and send your carb to motec.
Mopower
03-22-2005 06:15:40
I pull a mild UB running about 65 h.p. and depending on how wet the clay track is, we can bog it down with 15.5 on it. On a stocker I'd stick to a 13.6 or 15.5. They are shorter than a 14.9 and get a good grip although if you can turn a 14.9 nothing wrong with that. Youd probably need at least a good 85 h.p. to play with an 18.4 depending on what classes you pull in.
Andy2
03-21-2005 20:55:14
I think that is too much tire unless the tracks you pull on are loose and gravely. A lot of stock classes don't allow tires that big until you get into heavier classes,(8500 and up around here). If you are pulling 5500-6500 14.9X38 would be a good size.
