rims for sale?
family traditio
03-20-2005 17:03:08
anyone have any 9 bolt 16" or 18" pressed rims they wanna sell?
IAPuller
03-21-2005 16:02:54
 Re: rims for sale? in reply to family tradition, 03-20-2005 17:03:08
Actually I was looking for a pair of 13.6 X 38's for Divison II on nine bolt pressed steel. Thanks! And also my grandpa is looking for 15.5 X 38's on 9 bolt pressed steel too! Thanks!
JPatton
03-21-2005 14:27:14
Are you looking for 34 inch or 38 inch rims. I have a nice set of 16X34.
Jerry
deadeye
03-21-2005 05:38:45
I have a set of 16 X 34's 9 bolt for $250 located in Northern Iowa. E-mail is open.
DP
03-20-2005 21:35:40
I have a set of 18 X 38 9 bolt wheels with 18.4X38 8 ply tires mounted, that have been very good to me. I have to go to smaller wheels and tires due to rules changes. I've run these as low as 4 PSI, and always have a flat surface at the bottom of the tire track when unhooking. I will not seperate tires and wheels. These are presently on a John Deere G, but I will be taking them off. If interested, email me, and I'll give you more onfo if wanted, and phone # so you can call. I'm in the midwest.
bigt
03-20-2005 18:42:53
i have a set of 16 wide 9 bolts they are white and are in great shape 225.00 no rust at stem hole tn
bigt
03-20-2005 18:41:26
8n puller
03-23-2005 17:41:42
 Re: rims for sale? in reply to bigt, 03-20-2005 18:41:26
Where are you located? Do you have tires with the rims? E-Mail me maby we can get together. I need them for a super 77 diesel
IAPuller
03-20-2005 19:00:32
Jeremy4430
03-20-2005 17:16:08
I have a set of 9 hole X 38's for sale. they are 16 wide. they are a little heavy. center ring around bolt pattern is double. I want $250.00 for them. they look differant, the center is all a solid circle.looks good. send me an email and I will send a couple pictures back. I could deliver these to Princeton In if needed to..
ol George
03-21-2005 18:33:53
 Re: rims for sale? in reply to Jeremy4430, 03-20-2005 17:16:08
Got a set of 12*38 can mount a set of 15.5 on them or a set of mis match 13.6, cheaper than they should be.
