830 overhaul
rrperformance
03-20-2005 11:59:05
Can anyone tell me how far an 830 (2 cylinder) can be over-bored? If something larger than 0.120 is permissible, where do I find pistons? I have a messed up bore that 0.120 over will not clean up.
Thanks in advance,
rrperformance
ZekeMiller
03-21-2005 06:00:30
 Re: 830 overhaul in reply to rrperformance, 03-20-2005 11:59:05
I have heard something about a cummins piston that might work with some pin bushing work, but I do not know enough to give you sound advice. The guy to call would be ROBERT SOX TRACTOR ENGINES 910-422-9503 (from casepower"s web site). A guy on here called 820puller told me about Robert and had nothing but phrase for him. If you ever seen 820puller"s 820 run, you will see someone knows there stuff. Best of luck.
