JD H PULLER
upperpinecreek
03-15-2005 09:15:05
does anyone know a person who built and successfully pulled a JD H and if so what weight classes?
shutt30
03-17-2005 08:44:06
 Re: JD H PULLER in reply to upperpinecreek, 03-15-2005 09:15:05
A GUY HAS A STROKER H PULLING IN 2700 AND 3200 UP HERE IN CENTRAL MN. DOES OK IN THE 2700 BUT OUTPOWERED IN 3200.
upperpinecreek
03-16-2005 06:12:51
thanks for the response
CLIFF
03-16-2005 16:38:49
 Re: JD H PULLER in reply to upperpinecreek, 03-16-2005 06:12:51
Theres one that pulls good in central Pa (williamsport aera) 2500/3000lbs classes
a puller
03-15-2005 18:42:04
yes, two cyl. is right...there are two that are for sure, and i know of one that used to be pulled fairly sucessfully on concrete back a few years ago when they had a percentage pull....the two that are still around, one has about 28hp, and the other somewhere like 24....
2 Cylinder
03-15-2005 14:06:16
Yes there are several in the Central Michigan area that are pulled in the 2750 lb. class only.
