John Deere Cams
Ohio G Puller
03-11-2005 12:34:07
I would like to know if JD 720 gas cam is the same as the JD G R 900? I would like to know the lift duration and center line of the 720 gas cam?And if it will interchange in a JD G?
buickanddeere
03-11-2005 13:52:08
 Re: John Deere Cams in reply to Ohio G Puller, 03-11-2005 12:34:07
The G,70,720 & 720 cams all had the same lift and duration.
Mike Aylward
03-11-2005 16:55:43
 Re: John Deere Cams in reply to buickanddeere, 03-11-2005 13:52:08
Glen, it doesn't happen often but this is one time I have to respectfully disagree. The late G and 70 tractors use the same F900R cam but the 720's and 730's use a totally different cam with vastly different timing events. I don't have the information in front of me right now but they are indeed different. If memory serves me right the lobes have different spacings as well. Mike
buickanddeere
03-12-2005 14:55:24
 Re: John Deere Cams in reply to Mike Aylward, 03-11-2005 16:55:43
Back several years ago Two Cylinder Club published some of the 20 series engine specs which are rarely seen. I lost a photo copy of that data in a 2001 move so maybe my memory has failed me. I was positive the only difference was the distributer gear stuck on the end of the 720 cam? A fresh reground cam from Roberts instead of a worn 720 cam maybe an option?
