Info Please
Neff
03-10-2005 16:59:36
I have a 1955 JD 70. Ive pulled this tractor for about 2 years or so. Last summer I put new 7 inch pistons in it( power block no doubt). It is set up for a 9.5 stroke. It has a really nice head ported and polished with matching LP intake and exaust. The intake has been totally opened up. It currantly has a magneeders mag on it . 18.4 38 tires cut on 19 inch pressed steel. It also has a schwarts wide front on it weight brackets and adjustable hitch. The cam is a stock 70 cam and the rockers have been cut also big valves. The pistons have less than five minutes on them and Im having the spark plug holes on the block cleaned up right now at the machine shop. My question is what is something like this worth or should I fix it then sell it. The crankshaft is cracked . If somebody had a 70 crank this would make a very nice puller . Im just not sure if I wanna fix it or not. Thank you for listening Tyler
Flogger
03-11-2005 08:32:32
 Re: Info Please in reply to Neff, 03-10-2005 16:59:36
Just my opinion but you'll probably take a beating if you sell it without fixing it. You'd probably come closer to getting your money back by parting it but that would be a shame if it's a really nice 70. Sounds like it would make a great project for some deere puller.
