4630 engine swap
DMont
03-08-2005 15:39:19
Has anyone put a 466 engine into a 4630 chassis, ie power shift trans? Any ideas?
DMont
03-08-2005 17:15:46
 Re: 4630 engine swap in reply to DMont, 03-08-2005 15:39:19
Thanks, I have ran across several 4630's that have had blown engines. The only drawback to a 4630 to my knowledge is the 1000 rpm pto shaft. They typically bring less than 4430's. Any other reasons they are cheaper?
CrazyAllis
03-08-2005 16:34:59
It is a drop in swap!We've done several,just remember the two extra holes at the top are just blanks.If you're using using a combine engine have your inj pump off the tractor recalibrated and use it,if it did not come with an aftercooler use the one from the tractor.If it's a later eng with the crank driven oil pump you'll have to get the drive for the tach from a late 40 series.Pretty straight forward really.
