?for L.W.
MMNM
03-07-2005 18:45:01
I have a 1953 UBU LPG moline.It is stock except for electronic ign.What can I do to make more horsepower?I pull in 5500,6000,and6500.We have a 5 mph limit.Any help would be greatly appreciated.Thanks,R.Wilson
MMNM
03-08-2005 19:45:37
 Re: ?for L.W. in reply to MMNM, 03-07-2005 18:45:01
IT was junk.I got it from a junk pile.It had been there since 1986.They were going to cut it up for scrape.
LW
03-09-2005 09:58:27
 Re: ?for L.W. in reply to MMNM, 03-08-2005 19:45:37
Hey its your do what you want with it atleast its another tractor saved from scrap, it will get more use pulling then sitting in the barn restored!
Andy2
03-08-2005 18:18:13
If you have a nice running stock UB, I'd leave it alone and look for a U with a stuck motor that needs an overhaul,(to build a puller). I hate to see nice running tractors gutted for pullers when there are parts tractors to build them out of....my 2 cents
LW
03-08-2005 18:34:10
 Re: ?for L.W. in reply to Andy2, 03-08-2005 18:18:13
I agree,I always buy junk!
G/MAN
03-10-2005 15:46:11
 Re: ?for L.W. in reply to LW, 03-08-2005 18:34:10
Oh, so THAT'S why you're into Molines, lol. ROFLMAO. Sorry LW, I couldn't resist...
MMNM
03-08-2005 17:58:30
I have 4206 heads
LW
03-08-2005 15:00:41
If it has to be stock appearing go with M-5to670 style block bore to 4.810 and G crank,depending on heads you can get to 110hp+, Or you can go 5.75 bore with what ever stroke you like and really make some power,You could stay with little bore and go up on the stroke, alot of different things you can do just depends on the amount of money you want to spend.
Mopower
03-08-2005 05:58:30
The simplest thing would be bored M5 blocks and pistons. That would raise your compression and cubes even using stock heads. What heads do you have? You could make 65 h.p. or so easily that way.
